'Spacely Space Sprockets'
- secaIIwarrior
- One of the Regulars
Got a question for anyone with the info, how do I find out what other bikes front sprockets will interchange with the xj600??? It's part of my Warrior project, I can't use the rear sprocket from the bike, and the current rear is substantialy smaller, and the bikes front sprocket is several teeth larger. So I want to keep a ratio for more bottom end power not so much top end, and this current setup makes it twice as far in the wrong direction. I know my current is a 16 tooth, but want to drop to a 12 or 13. The spline is the issue, I can deal with spacing. Thanks! rich
"Heaven goes by favor. If it went by merit, you would stay out and your dog would go in." Mark Twain
01 Warrior project (92 XJ600 Seca II), 79 XS1100 SF
