Factory Center Stand (Centerstand) Information
How-to's related to accessories and accessorizing the Seca II
While the overseas bikes (XJ600n and Diversion) received center stands from the factory, the US and Australia spec SECA II's did not. Yamaha did offer the centerstand as a factory accessory. The original part number was P/N 4BR-27111-00-00 which listed for $510. NOS or new-condition center stands do not crop up, ever, and used ones are quite rare and typically command $120 or more. If you are looking for one, eBay or eBay UK are about the only options.
Centerstand Hardware:
If you manage to find a centerstand without hardware or need to replace some worn-out hardware, you can use common Yamaha parts to do the trick as follows:
  • The Yamaha P/N for the rubber bumper is: 2GM-27114-00.
  • The Yamaha P/N for the spring is: 90506-40508 and/or 90506-23509. It is also used on the '01-'04 FZ1.
  • The Yamaha P/N for the hose is: 90446-29385.
  • The Yamaha P/N for the nut is: 90185-10091 (you'll need 2).
  • The Yamaha P/N for the bolt is: 90109-101E6-00 (you'll need 2). It is also used on an '07 FJ1300.
Centerstand Part Numbers:
The Yamaha Parts Fiche pages which include the center stand are provided below. I do not know if these part numbers are accurate in the US.
Click on image to enlarge:
