Radare's All-Inclusive Seca II Torque Specs
How-to's related to the engine mechanicals, clutch and gearbox
US Model, XJ600 and Seca II, Torque Specs:
These are the factory torque specs for anything I could find a torque listed for. You can also download a text file with this information.
If you find an error, please post the correct torque and I'll get the list fixed.
Tune-Up Items:
  • Oil Drain Plug: 31 ft-lbs
    Oil Filter: 100 in-lbs
    Spark Plugs: 108 in-lbs
    Exhaust pipe flange nuts: 132 in-lbs
    Steering head bearing ring nut: 37 ft-lbs to seat and then 156 in-lbs
    Valve cover bolts: 86 in-lbs
    Fork caps: 17 ft-lbs
Engine, Clutch and Gearbox:
  • Cam chain tensioner cap bolt: 168 in-lbs
    Cam chain tensioner mounting bolts: 86 in-lbs
    Camshaft bearing cap bolts: 86 in-lbs
    Camshaft sprocket bolts: 17 ft-lbs
    Clutch boss nut: 50 ft-lbs
    Clutch cover mounting bolts: 86 in-lbs
    Clutch pressure plate bolts: 70 in-lbs
    Connecting rod cap nuts: 18 ft-lbs
    Crankcase bolts: 17 ft-lbs
    Crankcase plugs (M10): 105 in-lbs
    Cylinder block to crankcase nut: 168 in-lbs
    Cylinder block to cylinder head nuts: 86 in-lbs
    Cylinder head cap nuts: 16 ft-lbs
    Engine Mount bolts:
    • Front: 43 ft-lbs
      Rear: 64 ft-lbs
    Oil-Filter adapter bolt: 36 ft-lbs
    Oil pan mounting bolts - 86 in-lbs
    Oil pick-up mounting bolts: 86 in-lbs
    Oil pump assembly screws: 61 in-lbs
    Oil pump mounting screws: 61 in-lbs
    Oil pump screws: 61 in-lbs
    Primary drive gear nut: 36 ft-lbs
    Shift cam retaining plate screws: 61 in-lbs
    Shift cam stopper screw: 16 ft-lbs
    Shift lever pinch bolt: 86 in-lbs
    Shift pedal linkage locknuts: 86 in-lbs
    Starter chain guide bolts: 70 in-lbs
    Starter Chain tensioner bolts: 86 in-lbs
    Starter clutch Allen bolts: 18 ft-lbs
Fuel & Exhaust Systems:
  • Exhaust pipe flange nuts: 132 in-lbs
    Exhaust pipe nuts: 168 in-lbs
    Muffler bolts:
    • M8 in size: 168 in-lbs
      M10 in size: 18 ft-lbs
    Exhaust pipe joint bolts: 168 in-lbs
    Carburetor heater thermoswitch (if equipped): 124 in-lbs
Ignition System:
  • Pick-up coil plate securing screws: 70 in-lbs
    Timing rotor bolt: 32 ft-lbs
    Signal generator cover screws: 86 in-lbs
Frame, Suspension & Final Drive:
  • Front Forks:
    • Cap bolt to fork: 17 ft-lbs
      Damper rod bolt: 22 ft-bs
    Handlebars & Steering Stem:
    • Upper triple clamp bolts: 17 ft-lbs
      Lower triple calmp bolts: 27 ft-lbs
      Handlebar bracket bolts (mounting bolts): 17 ft-lbs
      Handlebar end-weights: 19 ft-lbs
      Steering stem nut: 80 ft-lbs
      Steering headset bearing ring nut: 37 ft-lbs to seat and then 156 in-lbs
    Rear shock absorber bolts and nuts: 46 ft-lbs
    Swingarm pivot shaft nut: 66 ft-lbs
    Drive chain front sprocket nut: 80 ft-lbs
    Drive chain rear sprocket nuts: 43 ft-lbs
    Engine sprocket cover bolts: 86 in-lbs
Brakes, Wheels & Tires:
  • Caliper bracket mounting bolts: 25 ft-lbs
    Front caliper bracket Allen bolt: 17 ft-lbs
    Rear caliper pad retaining bolts: 86 in-lbs
    Front axle: 43 ft-lbs
    Front axle pinch bolts: 168 in-lbs
    Brake disc mounting bolts: 168 in-lbs
    Union bolts (banjo fittings on caliper & master): 22 ft-lbs
    Master cylinder mounting bolts:
    • Front: 78 in-lbs
      Rear: 17 ft-lbs
    Rear axle nut: 75 ft-lbs
    Torque link bolts and nuts ('92 to '96 model): 22 ft-lbs
    Torque link bolts and nuts (97+ model): 17 ft-lbs
Electrical System:
  • Neutral switch screws: 35 in-lbs (use loctite on these threads)
    Alternator:
    • Rotor bolt: 58 ft-lbs
      Cover Allen bolts: 86 in-lbs
    Starter mounting bolts: 86 in-lbs
    Regulator/Rectifier Allen bolts: 61 in-lbs
This topic has 3 replies
