Suspension setup with alternate shocks
Dave66
Hi all
I've got a 96 XJ60s with an d FZ6R rear shock on it.
On the lowest preload it has no static sag and only 25.4mm of rider sag on it
My weight is 163 pound
I know there are some others out there with this setup and my question is for them
Is this the same result that you got or is my shock messed up.
From what I have read you should have 35-40 mm of rider sag for the street.
This topic has 2 replies
