1997 xj 600 seca 2 front fork problems
MagnaXJ6
I am having troubles with my 1997 yamaha SECA 2 XJ600 front fork suspension. When im riding it feels like a jackhammer at times. The suspension jumps up and down. I have rebuilt the forks with new fork seals and 20 weight fork oil. I have loosened everything on the triple trees and front axle and jumped up and down on it to see if that will help. The tire looked a little bit crooked. I have changed rims and tires. When I first changed the rim and tire it seemed like it helped and then it started again. I was thinking about removing the top spring spacers.
Any ideas or suggestions?
Thx
This topic has 1 reply
