XJ 600 leaking gas from carb hose going into airbox
Bash205
Hey everyone, just finished restoring a 91 seca ii xj600 and drove it for a bit, let it sit for a week and when i went to ride today gas started flowing out of the tube going into the airbox between carb 3 and 4, no clue what could cause it. I’m attaching a photo, it’s usually going into the airbox but pulled it out to make sure that was the issue and yeah, it’s flowing a good bit of gas out, starts to leak a bit after it gets warmed up
This topic has 1 reply
