Loving Mini’s
arnehulstein
Yearns for The Scrambler
Ok, so this is mine. :)
It is a 2004 Mini Cooper S with a very nice leather interior. But what is more important is that there’s a bit of work that has gone into the engine. The head has been flowed and worked on, the inlet has been changed for a performance version, the bottom end of the block has been treated and the supercharger is now on a 17% pulley. Including some other things, the car is currently rated around 220hp. It is on coil overs with strut braces and normally sports 18 inch summer wheels. It is now on a set of 16 inch Mini wheels with winter tires that will be replaced by 17 inch wheels and winter tires soon. Not sure if I wanted to paint those white first or leave them grey the way they are now. We’ll see.
I still have a set of 550cc injectors in stock, which means that if I change the intercooler, the scoop and the cam, I should be able to get around 250+ from this engine with a custom map. That will probably be enough. ;)
Show me yours!
This topic has 27 replies
