So I replaced the wheels and was going thru the forks. On the way apart, the left fork kinda stuck in the extended position. Wouldn't move.
I mortared the tube a couple times and it freed up. Then everything seemed to go normally. But then once together..... Stuck extended again.
I suspect the bushings are wedged.
Anyone have some insight or experience the same?
