Hi all need help with guage replacement
You will need to modify the wiring. When I did it, I used the stock wiring harness for the Seca's stock gauges and headlight, then spliced those to the Radian gauges. Here's the wiring diagram you'll need:
http://www.xjrider.com/gallery/albums/u ... ayout1.pdf
Note that this diagram includes wire colors for the '92 model year. I don't think they changed but since you have a '95, you might make sure your wiring matches.
