Hi Guys,
Finally found the root of the dead short in the lighting circuit and have now fixed. That moment, when you make a change, turn the ignition, and All the lighting works after all this time, just fantatsic.
So with the lighting circuit done, its now trying to work out why the clutch wont actuate. The service manual says to insert the clutch rod, so the notch at the top of the clutch arm, is between the two embossed ridges on the cover, which it is, but whilst there is tension, its not possible to put it in gear, pull the clutch and roll the chassis backward and forward. The update video can be found below.
