Off-Idle Bog/Hesitation/Stumble: Let's figure this out with Science!
Thu Jul 13, 2017 10:44 am
Some observations while doing this:
The engine will not idle smoothly until the pilot jets are set consistently at a particular A/F ratio. Setting all carbs to 14.7 results in a very smooth idle.
Changing pilot jets independently from this setting will cause the idle to roughen out again. But changing all pilot screws the same amount, consistently, does not impact idle.
The pilot screws are much more tunable as they are screwed out further. In the 1-3 turn band, small adjustments in the pilot screw results in wide changes to the A/F. That is, a 1/16 turn in the screw might result in an A/F moving from 16.6 to 12.1. However, after about 3 turns out, the screws can be easily adjusted to meet a certain A/F ratio.
Casper
Almost as Awesome as Murdock
Region or State: Motor City (MI)
Motorcycles Owned Currently: 1994 XJ600, 2006 SV650
Thu Jul 13, 2017 11:27 am
That is good to know. Interested that the suggestion was to go to 2.5 turns out instead of something a bit of 3.
zoli2750
Region or State: europe
Motorcycles Owned Currently: xj600s
Tue Sep 19, 2017 3:17 pm
hi Radare,
do you still have with these setting the 4,5k rpm buzz?
zoli
Mon Sep 25, 2017 12:02 am
hi Radare,
zoli
Couldn't tell you, Zoli. Neither of my bikes have fairings anymore. But I would suspect, if I had them, yes, they would buzz. Its a nature of the engine design and not a symptom of the way it runs.
