Float seal trick!
- mrblueberry
- New to XJR
Carb float seal trick! Had issue with the floats not sealing dispite the carbs being clean. The float hieghts were correct and they floated. Seats looked good however there was almost invisible deposits in the needel seal tubes. I fixed this by taking some metal polish and cuetips and drill. You will notice the cue tips get black as the polish works . After polish use a dry clean cuetip to make the suface look like a mirror! NO MORE LEAKY CARBS Note: These were a dirty set of carbs used just as example!
