So hear i have 1992 red seca and 94 parts bike. Red bike has no spark all four cyl. :thumbdown: What ive done so far: I did the nospark test from this site. Coils check out resistance primary,secondary and caps. All of my saftey switches are good as tested. Pick up sensor is with in range for ohms.tested the whole wiring harness i even swapped from the other bike! Relays check out good! Fuses all good all test lead back to cdi box yellow bike also had a cdi box but no luck whit spark.could i have 2 bad cdi boxes?
Progress ive made: swapped the bent forks out for the yellow bikes striaght ones. I took swing arm apart cleaned and regreased bushings. I went throuhg the carbs and fuel pump gave them a good cleaning inside and out. Degreesed motor frame wheels chain and sprocket witch look goodbike was gross when i got it lol. Im conveting to a naked/streetfighter look.
Building one secaii from 2
- mrblueberry
- New to XJR
