How to Change the Forum Theme - Read this!
I will be setting the default theme back to the alpha theme here in a bit. For those of you who liked the standard prosilver theme, you can turn it back on by using the following procedure:
1. Log into your User Control Panel:
2. Select the Board Preferences tab:
3. Change the theme to the "prosilver" theme:
Last bumped by radare on Fri Apr 13, 2018 8:43 am.
