Years ago, I had a Virago that had a cheap ~$25 plastic throttle lock that installs between the inside edge of the grip and the controls. With the flip of a lever, it applies compression tension on the grip to keep the throttle from returning when released. To disengage it, just flip the lever back up (but it has to be done manually; no automatic option on the cheap ones). It's a simple concept and a good idea for many riders who only use it occasionally. Unfortunately, because it fights the throttle return pressure with tension, it doesn't hold permanently. Over time, the vibration of the bike allows the throttle to slowly return, thus losing speed. It's handy, but annoyingly less handy than you want it to be eventually; especially on long trips. There are a couple of better versions of them these days, even an expensive $200+ aluminum one that does have a brake disengage. However, after reading reviews, they all still suffer from the same problem; slowly losing speed due to vibration.
So, I've searched for some time for a better solution. I found one a couple years ago, but due to the price and the fact that I haven't really needed it, haven't tried it yet. As I'm actually in real need of one now, I'm seriously considering it. I wanted to put it out here and see if anybody had anything to say, or has had any real world experience.
They call it the "Throttlemeister Cruise Control Kit"
Again, it's actually a throttle lock, not a cruise control, but whatever. What's different about this one is that instead of wedging something between the controls and the grip, this one replaces your factory bar ends, and holds lateral pressure on the end of the throttle tube to hold it in place. While it doesn't disengage with the brake, it is still adjustable even when locked, and due to its design, it disengages when you manually roll the throttle forward (off). It's available in six different finishes, and once installed, looks just like a nice bar end, not a funky mechanical parasite attached to your bike. As an added bonus, they offer them in standard and heavy weights to help improve vibration absorption. Also, it requires no actual modifications to the bike. Some of the cheaper insert-style throttle locks require a screw hole to be drilled in the controls to hold it in place. This one simply installs in place of your bar ends. If you ever want to move it to a different bike, just put the factory bar ends back on, and all is back to normal.
The bad news is the price: $126 - $164 depending on size and finish. Most basic throttle locks run around $30, though the fancy auto-disengage ones can cost $200+. Either way, the Throttlemeister is still around half the price of a cruise control, and a lot easier to install.
The good news is the reviews: I've only found a few reviews here and there, but so far, they've been good. The only negative I've really found is people complaining about paying $150 for a throttle lock, but that has been from long-distance touring riders who upgraded from it to an actual cruise control. Even those people said that it did what it was supposed to do well. From that perspective (and with a wallet that thick), I might say the same thing. However, from my perspective, I see it as a throttle lock that actually works, costs half of a real cruise control, looks nice, and has the added bonus of being a heavier bar end for reducing vibration.
Here's one of the better YouTube reviews I've found (even if you decide to fast-forward through the installation process): [video][/video]
Here's a link to the kit that fits our bikes: AY1
So, what do you think? It's expensive, but for the look and reliability, do you think it looks worth it? Anybody ever got to use one before?
