Voting - Site How-to Contest
Which is the best How-to?
Poll ended at Fri May 06, 2016 8:58 pm
Valve Clearance and Adjustment
7
28%
DIY Timing Advance
2
8%
Rear Shock Replacement
2
8%
Bleed and/or Flush the Rear Brakes
2
8%
Clean and Reseal the Blue-dot/Gold-dot Calipers
0
No votes
Spark Plug Replacement
7
28%
Carburetor Disassembly and Cleaning (revised edition)
5
20%
Total votes: 25
[center]Image[/center]
The time has come to vote for the best of the new How-To's which came about as part of the How-to Challenge.
Review the following submission and cast your vote for the best. When reviewing, consider completeness, accuracy, user friendliness and fit/finish. Vote for the one you think is best in these terms. When the poll closes on 5/5/2016, the top-two rated How-to's will be announced winners and will receive the $100USD gift cards.
You may vote for two How-to's and may only vote once, but you may change your vote if you so-deem-necessary. There is nothing wrong with voting for yourself.
I've added the How-to's I found listed for the contest in the poll. If I've missed one, please reply and let me know and I'll update the poll. I also tried to put them in order they were posted.
How-to: Valve Clearance and Adjustment
How-to: DIY Timing Advance
How to: Replace the Rear Shock
How to: Bleed and/or Flush the Rear Brakes
How to: Clean and Reseal the Blue-dot/Gold-dot Calipers
How to: Replace your Spark Plugs
How to: Disassemble and Clean your Carburetors (revised edition)
This topic has 1 reply
