Hello, Bert. Welcome to XJR.
I'm thinking your rear wheel is slightly out of alignment, causing the rear rotor to sit askew in the caliper. Measure the distance between the swingarm pivot and rear axle on each side and check to see if its the same.
Rear brake sticking after chain/sprocket change
- radare
- Site Founder
- Contact:
