XJ600 Seca II Factory Specifications (Specs)
How-to's related to general use of your XJ600. This includes everything from how-to start it to how to find parts for it.
Yamaha XJ600 Seca II Factory Technical Specifications:
Here are the factory specifications (specs) for the 1992-1998 Yamaha Seca II. This is the most accurate information available and is courtesy of multiple internet searches including the Wikipedia entry. Many of them are taken straight from the General Specifications section of the Factory Service Manual. If you find information that is invalid, please let me know and I will get it corrected.
General
Model name: XJ600SD (Diversion, Seca II, XJ600N)
Model code:
  • XJ600SD 4DU (USA)
    XJ600SD 4DU2 (California)
    XJ600SD 4DU3 (Canada)
    XJ600SD 4EA1 (Australia)
Vehicle Identification Number:
  • JYA4DUEO*NA000101 (USA)
    JYA4DUCO*NA013101 (California)
    JYA4DUNO*NA12101 (CDN)
    JYA4EAT0*NA000101 (AUS)
    Availability (US): 1992-1998
    Availability (UK): 1992-2006
Original MSRP (US): $6,990 (1991) - $7,499 (1993) - $8,560 (1995) - $8,999 (1997)
Dimensions
Length: 82.5"
Width: 29.5"
Height: 46.1"
Seat height: 30.3"
Wheelbase: 56.9"
Minimum ground clearance: 5.91"
Basic weight (with oil and full fuel tank: 434 lb
Minimum turning radius: 102"
Engine
Type: Four cylinder parallel, Four stroke, DOHC with 2 valve per cylinder, Air cooled (All UK models have an oil cooler beginning with the 1996 model; US models did not receive an oil cooler)
Displacement: 599cc (USA, California), 598.8cc (CDN & AUS)
Bore & stroke: 58.5 x 55.7mm
Compression ratio: 10.0:1
Compression pressure: 156 psi
Carburetion: Four 28mm Mikuni BDST (BDS26) down-draft carburetors
Lubrication: Wet sump; 3300 cc capacity; 3.1 US qt
Max power: 61.0 HP @ 8500 rpm
Max torque: 39.1 ft.lbs @ 7000 rpm
Starter: Electric
Transmission
Gear: 6-speed, Constant mesh
Clutch: Wet, Multiple discs
Final drive: Chain
Electricity
Battery: 12 volt
Ignition: Electronic
Stator: 295W
Chassis/Suspension
Type: Double cradle, steel
Rake/Trail: 25'/97mm
Front suspension: Telescopic forks, 38mm
Rear suspension: Monocross, steel arm, spring pre-load adjustment
Front brake: 320mm Single disc, dual piston caliper
Rear brake: 245mm Single disc, single piston caliper
Front tire size: 110/80-17 57H
Rear tire size: 130/70-18 63H
Performance
  • 0-60 mph: 5.1 seconds
    0-400m: 13.7 seconds
Top speed: 117 MPH (190 KPH)
Average fuel consumption: 44 mpg (18.7 Kpl)
