How to: Check Valve Clearance
How to: Check Your Seca II's Valve Clearances
According to Yamaha, you should check and adjust the valve clearances on your Yamaha Seca II every 16000 miles or 2-years. Valve clearances should be checked and adjusted before syncing carburetors or performing any other engine tuning. Valve clearances should be checked and adjusted when the engine is cold.
What you need:
  • High quality feeler gauge set which measures 0.001" to 0.015"
How to check your valve clearances:
1. Remove the seat, front fairing (if equipped) and fuel tank.
2. Remove the airbox, carburetors and intake manifolds
3. Label and disconnect the spark plug wires. Remove the spark plugs.
4. Remove the valve cover.
5. Remove the timing plate cover.
6. Using the crankshaft bolt, rotate the engine counterclockwise until cylinders 1 & 4 are at top-dead center (TDC). The #1 cylinder is at TDC when the timing mark is in line with the pickup sensor (timing mark for cylinder #1 shown in red):
  • Image
6b. When the engine is at top-dead center, the cam lobes will point away from each other as shown below:
  • Image
7. Measure the clearance between the camshaft and lifter for the #1 cylinder. Insert the feeler gauge squarely between the two; the feeler gauge should slide in with slight resistance. Record the clearance of both the intake and exhaust valves. Repeat the same process and record the clearances for the #4 cylinder.
  • Image
  • Image
8. Rotate the engine until cylinders 2 & 3 are at TDC.
9. Measure the clearance between the camshaft and lifter for the #2 and #3 cylinders. Record the clearance of both the intake and exhaust valves.
10. The factory specs for valve clearance are:
  • Intake Valves:
    0.11 to 0.15mm (0.004" to 0.006")
    Exhaust Valves:
    0.21mm to 0.25mm (0.008" to 0.010")
11. If your valve shims fall outside of the factory specification, you will need to replace the valve shim to get it back into spec. Use the site's valve-shim estimator to determine which valve shims you will need.
