Chinese electric motorcycles
Found this on eBay while looking at Zero’s. Take a look. There are some really odd choices and a couple of intriguing ones.
https://www.ebay.com/itm/2020-Other-Mak ... SwQGtd1f6J
There are some things I’ve noted so far:
1. The sticker on the lower cowl has a lower case o on Official and Safety is misspelled with a c.
2. The gauge on the speedometer isn’t real. It’s a sticker.
3. The wheels don’t match
4. Are the brakes set up like a bicycle? It has two hydraulic master cylinders.
5. What goes in the gas tank?
6. The specs say 80kw motor. That”s about 105hp, right? So why only 55mph?
7. The left grip fas three positions, F, P, and R. Do you think that’s forward, park and reverse?
8. What is going on with the rear wheel? Is the motor actually housed in the hub?
9. The tires aren’t tubeless.
10.It doesn’t have a gearbox. Why is there a gear indicator on the speedometer?
This topic has 3 replies
