New Guy And His Impulse Buy Seca
kizersosay
Hi, new member here. Look what I picked on an impulse. It's a 95 Seca II. It's a beater bike but is mostly in tact. Only missing the airbox and a few plastics fasteners. The fork seals are shot to he11. The frame and plastic has a bad rattle can job and plastic is cracked in 4 or 5 places. The inside of the tank looks bad. Not a lot of rust but looks like someone did a bad cream job on it. It looks like there is a sheet of dirty paper in it??? Anybody know anything about sealing a tank? could it be patch material or something else? Really looks like almost an entire sheet of copy paper flopping around in there. I'm going to try to clean it with soapy water then CLR cleaner. Then I'll rinse it really well and let it dry. Put some gas in and WHAM! an instant Mad Max bike.
Looks really simple to work on. I got the tank off and the carbs look really good. The chick I bought if from said she had a shop clean them but never tried to get it running after. She said they need two carb adjustment screws?(anybody have a location pic of these). Surely she was not talking about idle adjuster. Also looks like the fuel filter is there but has no hose on the white end. Where does this go? Looks like a line from tank right to carb is hooked up now.
This topic has 12 replies
