Pertains to my Warrior project
secaIIwarrior
Motorcycles Owned Currently: 92-XJ600 79-XS1100SF
Fri Nov 11, 2011 2:36 pm
Thought I'd start a new thread with my problem so it might get a little attention, how much of a problem will be caused---- my front sproket alignment with the rear sprocket is off approx 1/4 of an inch, paralell, just offset inward .250 ?? Thanks!
"Heaven goes by favor. If it went by merit, you would stay out and your dog would go in." Mark Twain
01 Warrior project (92 XJ600 Seca II), 79 XS1100 SF
Fri Nov 11, 2011 2:41 pm
How much distance is between the front and rear sprocket?
Is it possible to shim the rear sprocket to attain the appropriate alignment?
secaIIwarrior
Fri Nov 11, 2011 2:51 pm
I might be able to shim half that distance no more, but not sure till I try, anymore and the chain guard will also have to modified or shimmed all the way around to allow for chain clearance.
Drapheus
Resident Expert
Resident Expert
Region or State: North Georgia
Motorcycles Owned Currently: 95 XJ600, 92 XJ600
Sat Nov 12, 2011 3:11 am
Just keep in mind that any difference in alignment is going to drastically accelerate the wear on the chain and sprockets. You need to get them as close to perfectly aligned as possible.
Andrew Long Motography
1Oldman
XJ600 Master!
XJ600 Master!
Region or State: West Coast
Motorcycles Owned Currently: 1993 Yamaha Seca II
Sat Nov 12, 2011 12:19 pm
I'm no expert but I think different front sprockets can be had with different offsets. You might try looking at a front sprocket for a bike with a wider back wheel. Or better yet call one of the sprocket suppliers and ask. Did we ever get those suppliers transferred over? I had some listed on the old forum.
secaIIwarrior
Sat Nov 12, 2011 12:49 pm
Well, I just came from the MC boneyard, several frustrating hours later and no luck, no bin either, had to physically remove all the sprockets I was camparing them to. Same with my intake hunt, no matches, this Seca is proving to be very proprietary, meaning, if it didn't come on this bike originally, forget it. So next, its either after market if available, or fabrication time....or before I get much further along, use a different power plant. :?
1Oldman
XJ600 Master!
XJ600 Master!
Sun Nov 13, 2011 12:21 am
Compared to the more high performance bikes of the time, not a whole lot of aftermarket stuff was made for the Seca II.
secaIIwarrior
Tue Nov 15, 2011 2:40 pm
:D Cut old and welded new
