After buying the bike I thought i'd do some routine maintenance including adjusting the chain tension, started winding back , then moved to the other side and edge of washer was much further from markings! Checked with a rule and one washer is about 20mm od smaller than the other! Doesn't make adjusting very easy!!!
Can anyone tell me what i.d. and o.d. the correct washers should be? Thanks for any help :huh:
