What did you do with your Seca II today?
Crimson
Region:: London
Motorcycles:: XJ600S
Mon May 22, 2017 9:41 am
Weather is great but couldn't ride (pending new reg-rec), so I took the bike out anyway and did some carb cleaning, resetting of the idle mixture screws (again) and bench syncing of carbs (again). Removed rocker cover, cleaned up the seals around the nuts and measured valve clearances (one is out).
https://crimsonxj.wordpress.com/2017/05 ... ces-check/
TonyKZ1
Region:: Missouri, U.S.A.
Mon May 22, 2017 9:53 am
Saturday, I installed a new set of sprockets and drive chain. As expected, sounds and works much better than a wore out set of sprockets and chain.
Mon May 22, 2017 10:12 am
What did you use?
MattP
Formerly spr1
Region:: Silesia
Motorcycles:: 1996 XJ 600 Diversion
Poland
Mon May 22, 2017 12:20 pm
I've read your blog-post - if you're still procuring the tool this vid may be of use https://youtu.be/yaismzIE0CE
In it's description is a link to vid where he uses it to remove shims.
Hope that helps.
'96 Seca II
Matt
Crimson
Region:: London
Mon May 22, 2017 1:21 pm
Hope that helps.
Thanks man. Amazing synth music in that video! Very creative... That tool looks clever, and I have an angle grinder to make it, but as I've already ordered one of those Suzuki-type shim basket pressing tool (one of those that looks like a C-spanner) I'll just wait for it to arrive through the post.
TonyKZ1
Mon May 22, 2017 1:59 pm
What did you use?
I got them at Bike Bandit, a BikeMaster 520x110 BMXR Series X-Ring Chain, and JT Sprockets Steel Sprockets with the factory 16/48 teeth gearing. I also picked up a new countershaft front sprocket locking washer. They are affordable and with the mother's days 10% discount, it was just under $112.
fateddy
Global Moderator
Global Moderator
Region:: North Colorado
Motorcycles:: 1996 XJ600N, 1991 Suzuki DR350
Mon May 22, 2017 7:54 pm
Finally finished running a distribution block and switched relay last night. I accidentally got the wrong part, a fuse block instead of a distribution block. However, spade connectors turn out to fit perfectly into one side of an ATO fuse slot, so I was able to fabricate jumpers. All I have wired up right now is my GPS, but there's spots for two additional accessories. I'll probably add a USB charger at some point for phone/GoPro/battery packs. If not, I'll pull the whole thing out and just run the GPS directly to a switched power and ground. But I'm happy with the fact that I completed an electrical project that works as intended without any blue smoke in the process.
Mon May 22, 2017 8:52 pm
Very nice work there, my friend. I am in the middle of the exact same thing on my Honda Rancher (for the plow and heated grips).
Mon May 22, 2017 9:02 pm
Started work on getting this poor thing back on the road :cry:
arnehulstein
Yearns for The Scrambler
Region:: Goes, Netherlands
Netherlands
Tue May 23, 2017 1:51 am
radare wrote:
Mon May 22, 2017 8:58 am
Man, ain't that the truth. And I enjoy both equally . . . :ponder:
Let me just say that I know that feeling very, very well.
