New member with a problem
Clutch93
Region:: IL
Motorcycles:: 1996 Yamaha xj600
Sun May 14, 2017 10:07 am
Hey guys, just bought a 1996 xj600. I paid $300 for it being in rough shape. It ran when I bought it, but only enough to go for a little test ride. So far I have cleaned the carbs, got a new fuel filter and changed plugs. After doing that, the bike ran much better. Now I'm stuck at this point here. I bought the fuel filter yesterday (the one that was recommended from autozone that fits in the factory mount. All was well when I first installed it, I cracked the petcock open and fuel rushed into the clear filter as it should have. Went for a 20 min ride and once I got home the bike began to sputter and lean out and then died. I looked at the fuel filter and it was empty! I have half a tank of gas and the fuel is on. I took the tank off again and with the lines off I turned the petcock to the prime selection and gas pours out as it should and shuts off on reserve as it should. Once I put the filter back on though, it wont fill up, inturn not letting my bike get any gas to run. Please help!!! Sos!
AlecJ
Region:: South Africa
Motorcycles:: yamaha FZS1000
South Africa
Mon May 15, 2017 1:51 am
Check if your fuel pump is working, mine died soon after getting my bike ordered a new one from ebay
http://www.ebay.com/itm/12v-60-LPH-Fuel ... UA&vxp=mtr
I ride solo
North1987
Region:: Ontario, Canada
Motorcycles:: 96 xj600
Mon May 15, 2017 10:24 am
Hey welcome to the site always nice to see a new member. When you have it on the bike and you turn it to the prime position do you get fuel? The only reason I ask is because it sounds to me your petcock check valve is stuck/ not working. Before we go down this path though it would be good to perform a quick test, with everything hooked up on the bike turn your fuel to the prime position. This will bypass the check valve in the petcock, confirming or eliminating the petcock check valve.
Mon May 15, 2017 12:19 pm
Good advice there, North. And Clutch, welcome to the site.
mikee112
User Administrator
User Administrator
Region:: UK
Great Britain
Mon May 15, 2017 12:26 pm
Hey Clutch, Welcome to the forum :)
