Hello from cool and wet Northern Ireland
raytherip
Region:: Northern Ireland
Motorcycles:: Yamaha XJS 600 Diverson
Sun May 14, 2017 1:11 pm
TonyKZ1 wrote:
Sat May 13, 2017 6:45 pm
Hello and welcome to the site!
Thanks I am still finding my way around
Many thanks regards
Raymond
Mon May 22, 2017 10:21 am
Man, I am way-late on all of these. Welcome, Raymond.
acanais62
Region:: France, Paris
Motorcycles:: xr 600
Thu Jun 08, 2017 9:18 pm
Crimson wrote:
Sat May 13, 2017 12:49 pm
Hello and welcome. I hope you stick around and post.
The clutch basket rattle thing is typical on these bikes. If you check this Youtube video, you'll hear what it sounds like:
https://www.youtube.com/watch?v=MhTUyYU1RsY
Sounds horrific but from what I understand, it's harmless. In case you're in doubt as to whether it's clutch rattle, this rattle is something you should only hear on idle.
The fix can be found online. It's a doddle, but there might be a difficult bit: having or making the right tools. You need a torque wrench and a 30mm socket, and a sort of rig to hold the clutch basket in place while you undo the clutch boss nut assurances deces. Then you can undo everything, put a tight-fitting steel dowel (maybe a section of an old screwdriver shank?) in place, and put it back in as it was. Personally, I don't have anything that could hold the clutch basket in situ while undoing the clutch boss nut. So, when I replaced my clutch plates and springs recently, I didn't even dump the oil - I just leaned the bike to its sidestand. This means I can revisit the oil gear dowel at a later date if I want. I can just pop it open again and have a fresh gasket handy.
Here is my account of clutch plates and springs replacement:
https://crimsonxj.wordpress.com/2017/05 ... gs-fitted/
My subjective view is that some clutch noise is gone. The plates were a very snug fit into the basket's teeth. Also, gear change is smoother, and there is no clunkiness between 1st and 2nd. When you do your plates, it would be a good opportunity to at the same time see if you have sufficiently meaty tools to remove the clutch basket to replace the noisy dowel.
Anyway, you've done a lot on your presentation. Cool when there are people who are more careful about what they are doing.
Posbike
Region:: MN, USA
Motorcycles:: 1993 Xj600 Seca II & 2016 Yamaha FZ-07
Thu Jun 08, 2017 9:49 pm
Welcome sir!
You can call me Al
93 Xj600 Seca II
16 Yamaha FZ 07
Minnesota, USA
Attended University of YouTube
