Part, Metal type (made of what type of metal??)
andrewed1
Region:: Sydney, Australia
Motorcycles:: XJ600 Seca II - 1992 & a 2nd 92 xj600s
Australia
Mon Jan 15, 2018 5:42 pm
OK this will sound weird, I need to find what type of metal some parts are made from
1> The front foot-pegs brackets are made from?
2> Carby Intakes tubes
Reason:
My are terrible, and was going to use a etching type acid cleaner or similar to clean them but need to get the correct type of acid for the metal type.
thanks
Mon Jan 15, 2018 8:36 pm
Both aluminum and both cast.
andrewed1
Australia
Tue Jan 16, 2018 4:09 am
Thanks
Tue Jan 16, 2018 10:05 am
Etching compounds with hydrofluoric acid should work. Don't let them sit for more than 30 seconds, flush liberally with water after those 30 seconds, and then brush/scrub without letting the part dry. Reason for the scrub is that a layer of oxide forms and needs to be cleaned off. If let to dry, the part will take on a dark grey weathered finish.
andrewed1
Australia
Wed Jan 17, 2018 4:36 am
Before and after shots...
i used a product called Blitz Aluminimim cleaner and left to soak over night.
active ingredient is: Phosphoric Acid Solution.
bottem
Region:: Bergen
Motorcycles:: 1998, Yamaha, XJ600N
Sun Jan 28, 2018 11:55 am
andrewed1 wrote:Before and after shots...
Great post!
I’ll give this one a try. The bike is in urgent need of some serious maintenance and cleaning.
Sent from my iPad using Tapatalk
