92 Stock & Racetech Fork spacer length
mbanzi
I am busy rebuilding the forks on my 92. I notice it has what appears to be Racetech fork springs, but the spacer tubes look WAY too short when I compare it to this image I found in another thread. Top spring is Ractech, middle is stock:
Does anyone have measurements handy for the following spacers:
  • Stock
  • Racetech
From scaling the image I calculate about 52mm for the stock spacer & 164mm for the Racetech. Am I close?
This topic has 2 replies
