Identify That Part
Full Circle
Resident Expert
Resident Expert
Region:: Ontario, Canada
Motorcycles:: 07 FZ6
Wed Jun 01, 2016 7:19 pm
1. Idle speed adjustment screw. Found between the number 2 n 3 carbs. Used to set your idle rpm.
2. Because it looks way too clean and pristine to go back on, it would get all gunked up-n-stuff
3. Sure, why not, unless... See answer #2
4. Magic or Divine Intervention, or maybe just luck ;)
How 'bout this...
*Edited #1 because I didn't answer all the questions from the original rules.
andrewed1
Region:: Sydney, Australia
Motorcycles:: XJ600 Seca II - 1992 & a 2nd 92 xj600s
Australia
Wed Jun 01, 2016 7:49 pm
Never mind
Full Circle
Resident Expert
Resident Expert
Wed Jul 20, 2016 6:09 am
BUMP??
SpeedRacerOnline
Buyin' the Goods, Online!
Region:: Michigan
Motorcycles:: '92 & '93 Yamaha XJ600S, '74 Suzuki TS185 Sierra
Thu Jul 21, 2016 8:27 pm
I totally forgot about this thread!
What is it?
1994-2002 Front Stop Switch Assembly (front brake light switch)
Where does it go?
Screws into the bottom of the front brake master cylinder on the right side of the handlebars
What does it do?
When the brake lever is pulled, it moves a plunger on the front stop switch completing an internal circuit to turn on the brake light
This was a tough one to figure out! I knew I recognized it, but couldn't think of where exactly, so I went digging through the diagrams. Apparently, the design changed in 1994, but the diagrams didn't. When you look at the parts catalogs, the part number for 1992 is 3YX-83980-00-00, 1993 is 3YX-83980-01-00, and 1994-2002 is 4BH-83980-00-00. The '92 & '93 versions look quite similar; flat and boxy. The '94 and up one is this more rounded version. However, for some reason, they never updated the image in the catalog. All the way from 1992-2002, the image is the same; the flat boxy style. That's a bit misleading! Since I have a '92 and a '93, I didn't recognize it from my tear down.
Okay, here's the next one:
- Speed's XJ Journal
bsw
Region:: NSW, Australia
Motorcycles:: A collection of old ones...
Sat Jul 23, 2016 6:47 am
Looks like a cam chain tensioner
Edit - oops, didn't read the rules...
Goes in the back of the cylinder block (under the carbs) and the plunger goes through the block and pushes on the cam chain guide/runner to keep the chain tight.
My bikes:
  • '82 CB250RS - Cafe Racer project
  • '89 K100RT - Cafe Racer project
  • '95 XJ600 Seca II - Cafe Racer project
  • '98 GSX250F - Needs work to get on road
  • '05 XVS650A - Wife's
  • '07 VL250 Intruder - was cheap...
Sun Jul 24, 2016 9:39 am
Using my all-arching power to move this one along :)
What is this part AND what does it do (don't forget that second part)?
andrewed1
Australia
Sun Jul 24, 2016 2:04 pm
*Updated with correct name and info*
Part is Called - 227 SLEEVE TENSIONER ASSY (Aust) or 4G0-11592-00-00 TENSIONER,CHAIN (USA)
Part number is: 4G0-11592-00
Location number: 45
http://www.partzilla.com/parts/search/Y ... parts.html
Tekken666
Region:: Poland
Motorcycles:: 2001 XJ 900 4KM
Sat Oct 08, 2016 3:41 pm
Maybe I will try to continue this very nice game :)
What is it, where does it go, and what does it do?
Stan_Ac
Region:: Germany
Motorcycles:: Severall Yamaha XJ600S and 900S
Germany
Fri Dec 15, 2017 11:14 am
This parts are used to connect the swingarm and the shock.
Forgot part two:
It is sitting deep down in the bike and you can find it between the shock and the swingarm ( before the wheel).
It Looks like this part is from any ohter bike than the Diversion.
Nothing is impossible...
