Gauges for Naked Conversion
mikehofmann21
Region:: Michigan, US.
Motorcycles:: 92 Yamaha seca ii
Fri Aug 10, 2012 6:13 am
Did you weld those brackets to the back of the tree Radare?
Sun Aug 12, 2012 2:45 pm
A good alternative to the Radian (YX600) gauges, might be the XJ700 gauges. They made the XJ700 in 1985 and 1986, here in the US. It used the same 4-cylinder engine and should have the same tach signal. It did use a 19" front wheel, so there may be speedometer discrepency.
93seca2
Region:: CT, USA
Mon Aug 20, 2012 8:02 pm
Will Maxim gauges work? There is a set on ebay but they are $$$.. Don't want to waste good money on other mods
I thought buying a bike was supposed to be relaxing.. :)
93seca2
Region:: CT, USA
Wed Aug 22, 2012 8:00 am
I just ordered a Radian cluster and will be here next weekish... My next question is, is there a wiring diagram that I will need to follow or is it plug n play? Man I can't wait to get this thing finished..
Wed Aug 22, 2012 10:44 am
93seca2 wrote:I just ordered a Radian cluster and will be here next weekish... My next question is, is there a wiring diagram that I will need to follow or is it plug n play? Man I can't wait to get this thing finished..
Unfortunately, its not plug and play. The indicator bulbs and holders will pop right in so they require no wiring. The tach will need to be cut and wired to the Seca II harness. The bulb harnesses will need to be cut and wired too. I'll take pictures when I'm done.
EDIT: Here's a wiring diagram I made for adapting Radian gauges to the Seca II harness:
gallery/albums/userpics/10002/Radian_Ad ... ayout1.pdf
93seca2
Region:: CT, USA
Wed Aug 22, 2012 2:03 pm
Thanks Radare!!
93seca2
Region:: CT, USA
Tue Aug 28, 2012 7:27 pm
Alright gauges have been delivered
greeny4704
Resident Expert
Resident Expert
Region:: marion ohio
Motorcycles:: 95 xj600 4k / 93 xj600 13k
Tue Aug 28, 2012 10:34 pm
93seca2 wrote:Alright gauges have been delivered
Got any pics???
BUILT NOT BOUGHT
fateddy
Global Moderator
Global Moderator
Region:: North Colorado
Motorcycles:: 1996 XJ600N, 1991 Suzuki DR350
Mon Jul 29, 2013 12:09 pm
Reviving an old thread.
Waiting around for a 96 fairing may prove fruitless, so I'm looking at going naked.
What gauges, aftermarket (Vapor, Acewell, etc) included, require the least rewiring. I'm not very good at electrical stuff and I'd like to do the minimum of cutting on my stock wiring harness.
wzc0014
Region:: Auburn, AL
Motorcycles:: 1992 Seca II
Mon Jul 29, 2013 12:46 pm
the fz600 gauges are a direct swap on the wiring harness. they can easily be mounted in some autometer cups too. there's a decent amount of people on here that have done this including myself, greeny, ride92, radare, drapheus and others check out some project threads.
