Jims XJ600N thread
Slartibartfast
Motorcycles:: 1999 XJ600N
Great Britain
Wed Aug 30, 2017 8:47 am
Hi folks
I figured it was about time that I started a thread in here for my bike. Its probably not really a project, not like some of the custom jobs and restorations on here, but its now quite tired and in need of some TLC.
A little about me: I'm an electrical engineer (on paper) but with mostly mechanical (hyd/air systems) experience from a career on Submarines. Comes in handy for playing around with tools, I dont have a huge wealth of experience with engines but can generally work my way through things (especially with the help of you lovely lot).
The current bike is my second XJ; the first was a 600S in red, bought as a confidence builder following a collision with a deer on my previous bike. I sold it to move house and then bought my current 600N 3 years ago. Two Scottish winters have not been kind to it!
Its been off the road since the middle of last year due to work, family and a new hobby (MTBing) taking over. To be honest I'd kind of lost the buzz that biking had always given me. A mate (who has just passed his Part 1 test) has managed to give me the buzz back with his enthusiasm for biking, so last weekend I dragged the bike out of the corner of the garage (took an hour to free the brakes and wheels up), charged the battery, and she started without too much hesitation :)
So I've spent the last couple of hours crawling around it and have a list of jobs to do:
Brakes - new hoses, pads, seals, caliper paint - a full system overhaul
Wheels - paint, clean up discs, new tyres (front is gubbed and I have a new 4 inch rear with no tyre on it)
Chain - you'll see why in a minute!
Swing arm removal - to address corrosion issues and check / grease bearings / pivot points
Shock removal - as above
Oil pipes - wow, these are seriously manky!
Painting - touching up other bits to prevent corrosion getting any worse
Cleaning/degreasing - all the other bits that aren't mentioned above
Full service - I did the valve clearances less than 1k miles ago so dont plan on doing that this time round
Things I've already done since I bought it: new fork seals and 15wt oil; valve clearances and service; new chain and sprockets (-1 tooth on the front); heated grips (toasty); petcock overhaul; starter motor rebuild.
The good bit is that the engine runs, all the electrics/switches etc work, and I replaced the entire exhaust system 18 months ago so no issues there either.
If you've read all of this, wow you're patient!!! So heres some pictures of the bike in its current state!
Horrible oil pipes - anyone know where to get (or what to use as) replacements? The usual suspects dont have them!
Dont think its worth trying to clean this!
Front brake reservoir needs painting:
Same with the calipers (they're all similar!)
EIF wrote:
Tue Feb 13, 2018 12:39 pm
Rdrasher
Region:: Florida, USA
Motorcycles:: (3) 92 Seca II's, 1993 GTS1000A
Wed Aug 30, 2017 7:49 pm
your pics are not coming through.
Wed Aug 30, 2017 8:07 pm
Photobucket really hosed its users with the hosting restriction and fees. Jim; if you get a chance, shoot the pictures up on the site's gallery (it's pretty easy to use) and share 'em with us. I'm excited to see the progress.
div
Region:: France
Motorcycles:: XJ600 Diversion S (97)
France
Thu Aug 31, 2017 5:42 am
Lot of rust there! Scotland is really a wet land ;)
Good luck you have some work!
My project : '97 XJ600 S Rebirth
XJLiverpool
Region:: Northwest, Liverpool, UK
Motorcycles:: 1992 Yamaha XJ600S (seca II)
Thu Aug 31, 2017 5:55 am
I might have a spare swingarm, I'll have a look around when I finish work tonight for you if you're interested.
I live just a little South of you about 300miles south that is lol
Slartibartfast
Great Britain
Thu Aug 31, 2017 9:40 am
Yup. Combined with the incredible amount of grit that gets put down from October through to March (sometimes Sep-April!) it just eats things. Unfortunately you cant let the weather stop you doing things or you'd never do anything!!!
Cheers dude thats very kind; I'm going to strip it back and see how bad it is - the main arms of the swingarm seem ok its just the front end, I guess I'll see once I get it off the bike and cleaned up
Slartibartfast
Great Britain
Tue Sep 19, 2017 2:19 pm
Finally managed to grab an hour in the garage today, and as I'd started at the aft end I thought I'd dismantle the rear brake caliper and torque arm as they're next in line for paint.
I hate brake calipers.
I used the brake pedal to push the pistons out as far as they would go and then split the caliper but still can't get the pistons out. Looks like I'll be finding a compressor at work, unless someone has any other top tips?
The pads, shims, etc are all pretty corroded. I'm going to try a vinegar bath to remove the rust - I reckon I can fill one for about £1.50 so it has to be worth a go!
I'll keep you posted...
Slartibartfast
Great Britain
Wed Sep 20, 2017 2:49 am
Success!!!
Sometimes it's awesome having access to tools at work 😊
This time it was a grease gun and variety of attachments for it. With the rear caliper split, the attachment below goes straight on the bleed nipple. You will also need a bolt to blank the banjo bolt hole on the appropriate half of the caliper.
All you need to do then is hold your thumb over the internal port that links the two halves and get your mate to pump away! Leave your thumb off till grease comes out. Then hold it and three/four pumps on the grease gun and out they come!
All I need to do now is wait for the wife to go out so I can fire the bits through the dishwasher....
Casper
Almost as Awesome as Murdock
Region:: Motor City (MI)
Wed Sep 20, 2017 6:48 am
Not sure if joking... but don't think that's a good idea. It's a pain to try and get that grease and grime out of the dishwasher. I have a friend that used his for a parts cleaner once, he has since replaced it due to this usage.
Slartibartfast
Great Britain
Wed Sep 20, 2017 8:15 am
Hahahaha as much as anything it's to annoy the wife 😂 I've used it a couple of times but to be fair I've got the vast majority of the grease off things by then.
You can just about fit a wheel in one 👍
