Diversion adventure project.
Sat Aug 12, 2017 1:03 pm
SuperDev13 wrote:
Sat Aug 12, 2017 12:34 pm
Project looks great and I couldn't help but laugh at the tank incident.
What do you mean?
Fenty
Region:: Manchester
Motorcycles:: Yamaha xj600s diversion '93
Sun Aug 13, 2017 4:49 pm
Pt. 6. - Miscellaneous Tinkering.
Hi all, first off thank you for the feedback and support. I'm glad to see the work so far and the concept is well received.
So there has been a fair bit of messing about in the garage over the past week or so and I stupidly failed to take any photos of most things I've done. I got too involved with what I was doing that the camera became an oversight so my description alone will have to do for most of it.
At the start of the week I set out to satisfy a niggling concern that the new exhaust sat slightly higher than the stock exhaust on the bike.
My concern was that I may have inadvertently ruined all my hard work on the pannier rack in this oversight. If you were curious about the Delkavic exhaust, I can safely say it's fantastic, however something considerably less fantastic was being right. The end of the cans were around half an inch too high to get the boxes positioned on what I was fairly certain was their lowest fitting.
By this stage I've spent a total of around four days building this rack to fit as well as my skills would allow so to say I was disappointed would be an understatement.
Around an hour later I had carefully and successfully negotiated the cans into a slightly lower position so everything just about fits where it should. Crisis evaded :)
Moving on to the next hold up - there is no possible way I can think of that allows me to use the stock indicators with the panniers positioned as they are, I had contemplated fitting them to the bottom of the reg plate so they sit just below the pannier but I wasn't fond of the appearance, I'm also not sure if it's legal and I had my doubts about their security fixed to a piece of thin plastic plate threatening to get dragged into the back wheel.
Another option was a set of mini indicators to fit in the original position but small enough to allow for the boxes. Simple, easy and convenient. This idea does come with the drawback of the indicators only being visible from directly behind leaving them quite redundant for changing lanes on the motorway... NEXT!
Ok, third and final idea which seems to be the winner. Get a set of indicators intended for mounting to fairings that sit flush to a flat surface. These can be fitted to the back of the boxes and wired in through the box. Sturdy visible and simple!
Though they are as cheap as a tank of fuel, funds have dried up for the month so they will have to go on the waiting list for now.
Next on the to-do list was to locate the cause of my intermittent brake light issue. Sometimes it works fine, sometimes it needs persuading to work and on this occasion it was flatly refusing to work.
- Advanced warning. A can of worms is about to be opened -
Starting with the back brake, a bit of wiggling and stomping on the pedal got it working but it still wasn't very happy so I started pulling off fairings to inspect the wires, there it is, a snag in the wire, touching but only just... soldered, taped and test again, this got it working but the pedal is pressed to a point where my wheel would be locked up and preparing to launch me over in retaliation. A simple enough adjustment on the height of the switch and the back brake lights up nicely.
Now to the front brake where things stop being simple. The brake lever is having no effect at all on the light so again try wiggling the wires, the light flickers but the lever is still having no effect. I try pushing the wires towards the switch to diagnose a poor connection, the tail lights up, great stuff... except my hand isn't pulling the lever at all. I try moving the wires again just to be sure and get the same result. At this point I should have grabbed a light to see clearly what was going on, but I didn't, I continued to fumble around...
Once again I made a sudden loud noise in the garage that my neighbours may be judging me for.
If you check on your own cherished xj600's you may see behind the front brake switch a plug that connects from the switch into the wiring harness. On mine no such plug exists, just two bare wires stuffed in - or more accurately near - the contacts... and I stuck my finger in there...
So there are some faulty electrics, good to know!
Of course this prompted a full strip down and inspection of the rest of the wiring. As far as I could tell the rest of the plugs were present and accounted for but that was where the good news ended. A large portion of the looms insulation has been taken off so there was a hopeless tangle of wires stuffed under the air box and there are 3/4 wires that have just been chopped and left exposed. I don't know their purpose yet but there's going to be a fairly large chunk of time committed to fixing this. For now I'll just have to to insulate everything as best I can and hope I don't start a fire.
New days work... this time I remembered photos. So the pannier rack fits, I'm waiting to get some nylock nuts so I don't find myself constantly re-tightening everything with the vibration and I need to fit some steel backing plates inside the boxes for a bit more structural security but today just consisted of filing and grinding down all the rough edges and painting.
On with the primer. Little effort for a perfect finish was made. Most of it will be consealed on the bike, this is just for rust prevention purposes.
One coat - black
Two coats black and hang to dry
Meanwhile I'm presented with time to prep the boxes for use, drilled out the odd rivets left in place by the previous owner, there were few clues what the boxes did in their previous life, but they were scattered with fine grey dust and air rifle pellets... just in case you wanted to know. Once all the rivets were out I filled in all holes with silicone sealant and gave them a good clean. They're not particularly pretty but pretty wasn't in the criteria for my needs so they'll do just fine.
That's all for now, there will be more details when I start fitting the panniers or attack the wiring harness, whichever comes first.
There's still plenty to be done yet before this old girl will pass for an adventurer and of course the updates will continue as and when.
Rubber side down.
Fenty
Region:: Manchester
Wed Aug 16, 2017 11:27 am
Pt 7. I almost have panniers!
As mentioned previously the rack was completed, test fitted and painted.
At this point I suspected there may have been a waiting period for the elusive payday but I've cashed in my penny jar and got things moving again.
The indicators have been ordered and are due to arrive early next week and the essential purchase of 100 nyloc nuts has left me with approximately 80 spares once fitted to the bike...
With all parts gathered for the rack it can now be fitted and left on. The long term plan is to use the stock indicators that patrude the rack while the panniers are removed. The new indicators can be permanently fixed to the boxes that can be plugged in easily under the seat.
Perfect photo oppertunity, freshly washed and racks fitted, I'm quite fond of this look.
In the preparation for the final fitting I've been giving some thought to the appearance of the boxes, and I have to admit, they are a bit of an eye sore. I thought I'd make that extra bit of effort with them and paint them with the last of the black frame paint.
Step one. Masking - so much masking.
Step two. Apply a heavy dosing of black gloss, wait a day then apply another heavy dose.
Step three. Delicately peel off masking tape
(Optional step. Curse failings of step 1)
Step four. Attack rough edges with razor blade and enjoy finished result
At this stage I can pretty much call this section finished, there will be photos of the completed luggage section once the indicators arrive and have been fitted but the build is complete pending final assembly.
Further down the line I will also be fitting a top box to complete the back end luggage - and give the impatient Mrs her all important throne at the back. This will obviously require further modification to the rack to mount because I've already taken up the mounting points of the bikes frame but that's for a later day.
Rubber side down.
GAU-8
Region:: Houston, Tx
Motorcycles:: 97 seca II
Thu Aug 17, 2017 3:12 pm
Good stuff!
Fenty
Region:: Manchester
Sun Oct 22, 2017 2:39 pm
Pt. 8 - The first adventure.
All has been quiet for a while and it’s not because I lost interest. I have been busy racking up some miles... well, that and I’ve been slightly preoccupied building a new bike from the frame up.
In all honesty the divvi has become a true work horse, used for my daily commute and nobody is interested in hearing the tale of a bike going to and from work 5 days a week leaving nothing to report besides an admiration for the pure consistency and reliability this machine has to offer.
Anyway, on with the point. I decided this bike was to become an adventure bike - or a poor mans best effort if you like - so previous work led to the point where we needed to hit the road for an adventure, and adventure we did...
Some months ago I got the approval from work, a week booked off in the middle of October. Who cares what the weather is like? I’m an all seasons rider anyway. Of course the reality didn’t sink in.
The date approached and the weather got colder and wetter and I started having second thoughts - nothing some name calling and advice on effective waterproofs from my dad couldn’t cure - I got a rough indication of the route around Wales planning to leave Monday and be home Friday. Heading from Manchester to Anglesey, to Tyn Cornel. Heading further south to St David’s, then back north to Dolgoch. Back to Anglesey then head home to Manchester... That sounded great, however the extent of MY plan was to follow my dad and ideally not fall off.
After work I headed home on the Friday before leaving knowing I had 2 days to make the divvi battle ready, a quick trip to the auto parts shop to pick up a set of heated grips because there is no way I’m leaving my Knox gloves at home but I knew my hands would freeze.
The bike got the full inspection the only problems I encountered was a torn fork gator exposing a leaking oil seal and a loose gear linkage nut... too late to change the seals, I’m sure they will be fine. With everything checked and tightened, the panniers fitted and luggage packed I was ready for the morning departure.
Day 1 - Manchester to Anglesey. The Met Office issued weather warnings about storm ‘Brian’, recording winds up to 90mph in places. The sun had turned orange in the sky and every few miles I would get an unsettling shove from the side as the wind got around trees and trucks, the storm was certainly making its self known. after a few more involuntarily lane changes I arrived at the meeting point with my dad in Chester. This was the last time I saw a motorway for some time.
We made a mad dash over the mountains heading for his house in Anglesey to bunker down for the night hoping the weather was better in the morning. However the wind still promised chaos for the journey - at one point I had a heart stopping moment thinking my back tyre had punctured at 70mph. Thankfully it was just a side effect of being beaten relentlessly as I rode.
Eventually we arrived safely.
The bike had shelter from the rain but managed to get pelted with numerous mop buckets being thrown around by the wind through the night.
Day 2 - Anglesey to Tyn Cornel. We were up and out bright and early on a cold morning and I instantly fell in love with the new heated grips. We passed through a bit of the rush hour traffic getting back onto the mainland. I discovered filtering (lane splitting) is quite difficult when the widest part of the bike is behind you, but it was over quickly. Anglesey at rush hour is about as busy as Manchester in the dead of night so it was a pleasant change of pace for me.
Onwards through Snowdonia following the narrow windy tracks that showed the aftermath of yesterday’s storm, tree debris all over the road. My riding skills and confidence in this terrain still had plenty of room for improvement, the difference in experience showed almost immediately, riding smooth bends on well maintained tarmac on good road tyres and I could not for the life of me keep pace with the Honda Transalp in front of me wearing knobbly tyres. Every corner, every damp patch, anytime a pile of leaves were on the road I was slowing right down in fear of sliding into a stone wall. I was kicking myself knowing my younger self would have flown through no problem, all the knowledge was there but the years sat in a car had taken my confidence hostage.
We stopped to appreciate the sights of Snowdonia shrouded in trees boasting their vibrant autumn colours while I was informed Wales had plenty more of this to offer as the miles go on.
On we went through more fast sweeping smooth roads. As the miles went on the divvi started to really shape up, a good hot run in cool clean air made a huge difference to the engines mood. We arrived at our destination, a wilderness hostel in Tyn Cornel. Over the mountain, down the dirt track, a bit of off-roading and left my phone signal a few miles behind.
The bike struck lucky and got to spend the night in the barn filled with firewood.
Day 3 - Tyn Cornel to St David’s Via Swansea. It rained. A lot.
It wasn’t too bad as we set off in search for civilization. We wondered our way down to Swansea but as we plodded on the rain caught up. We stopped for food by the football stadium in the hopes that it wold pass over us but we were not so lucky. Instead we decided to get on the motorway for the first time since covering the entire length of the country and make a mad dash to our hostel in St David’s. A few dull miles on the motorway in driving rain trying to find the coast.
... Of course once we stopped riding the rain stopped and the skies cleared for the evening.
Day 4 - St David’s to Dolgoch via Aberystwyth. Once again, up and out early, greeted by better weather and more miles of outstanding roads on our way to Aberystwyth tracking down a bike shop for a rain cover as our final night had no barn to keep the divvi safe from the elements. I figured she earned a new coat as she’d performed faultlessly so far. The only times the toolkit came out was to re-glue the new grips and to tighten the mirror after a fair amount of vibration had shaken it loose, both errors were my own fault.
We found my new cover at a little gem of a shop by the sea front called ‘Electra Moto Gear.’ Bike gear, coffee and cake all in one place, what more could you ask for?
After that we had a quick stop for food before pressing on to Dolgoch where we encountered some more intense off-roading to reach our destination and I had my first river crossing. Only a small one but I nearly ended up sideways and wet all the same. Stumbling up the bank with steam billowing from the down pipes to see my dad laughing fumbling for the camera. After nearly dunking myself I wasn’t quite ready for the second take photograph so we carried on rumbling over the dirt track to our third and final wildernesses hostel. No phone signal, no electric, just solar lights and torches in the middle of a valley which almost spelled a great night a sleep... 4:30am i’m Awake and startled in the darkest room i’ve ever been in. Woken by the pain of a recent dentist visit my dad decided he didn’t need pain killers but he would use his vape, subsequently setting off the smoke alarms throughout the building... We’re not on fire, go back to sleep.
Day 5 - Dolgoch to Manchester Via Anglesey. We set off in persistent rain trying to stumble back over the dirt track that led us here - I decided the bridge was a better idea than a second attempt at the river- once again back into civilisation to make some phone calls and reassure relatives and loved ones that I was alive and well despite my phone not working behind the mountains. The weather was miserable and made no indication of change so we pressed on fast before stopping for food in snowdonia while the weather improved. This gave time for some reflection over the journey near its end. The 24 year old divvi with all its previous loveless owners and pitifully low mileage had done better than I ever imagined it could. This also gave me a huge sense of satisfaction realising I was probably the first owner to ever take her on a trip like this, I felt better for it, my riding was much better for it and the bike felt hugely better. Long fast paced journeys in clean air to clear out the filth of city centre bus fumes and traffic jams.... the Transalp never missed a beat either but that had been tried and tested in various parts of the world already...
Enough sentimental thoughtfulness staring at the two bikes. Back on the road to Anglesey for a quick coffee and part ways with dad.
Let’s get back to Manchester.
Home and covered in mud. Notice how my chicken strips are less than half the size they were before setting off...
My welcome home party was awaiting me straight after the first ‘Manchester’ roadside where I was made to sit in bumper to bumper traffic, unable to filter with the panniers, feeling the divvi get hot and bothered again. 1 hour and 45 minutes later I’d covered the last 20 miles to my front door.
There are a few little additions I have in mind for the divvi as I will certainly be following up with more trips once the worst of winter has passed. For the benefit of my previously broken wrist I’ve invested in some bar risers for a slightly more upright riding position. This will in turn most likely present the need for a taller wind screen.
A large top box will be much better suited than the panniers for any trips without the Mrs on the back purely for the benefit of filtering.
Oil seals and new fork gators will be needed as there is now fork oil all down the leg after the rough terrain.
And of course the previously mentioned respray on the tank and a new seat cover but they were on the list.
For the most part however, she’s set a fine example of how easy (and cheap) adventure riding can be. You don’t need a big heavy bmw to go down a dirt track, you don’t even need a modern bike to do it. This divvi is ready for anything I can throw at it and my admiration for it grows with every journey.
Not bad at all for 24 year old jap-crap.
Rubber side down.
XJLiverpool
Region:: Northwest, Liverpool, UK
Motorcycles:: 1992 Yamaha XJ600S (seca II)
Mon Oct 30, 2017 5:52 pm
Absolutely fantastic story, really loved it and got invested !
Literally you've done something I reallllllyyyy want to do with my divvi and that's to on a loooong haul journey round trip.
If you're ever planning another trip please feel free to give me a shout as I'm just down the M62 :)
Also if you use an App called WISH they sell knock off products, I picked up a touring screen that takes away that horrible head wobble at 80/90mph on the motorway, for just £30 and arrived in two days. (Granted a slight increase in wind noise, nothing crouching down or ear plugs don't fix)
Ramble over, fantastic story. I look forward to more eventually, stay safe rising through winter if you are :)
