Project: Dzida
ride92
XJOTM July 2013
XJOTM July 2013
Region:: Wisconsin
Motorcycles:: 1992 Yamaha Seca II
Tue Sep 24, 2013 1:56 pm
1Oldman wrote:Doesn't sound like you're using your full rpm range. The power doesn't really come on until 6,000 rpm then it pulls like gangbusters to 11,000. Give it a try.
Isn't redline at 9.5K? Why would you go up to 11K?
1Oldman
XJ600 Master!
XJ600 Master!
Region:: West Coast
Tue Sep 24, 2013 2:15 pm
Well, you're right but quite often I run it up to the rev limiter in first gear, where ever that is, just because it gets there so fast. And it's kinda fun.
jaszczomb
Region:: Łódź, Poland
Motorcycles:: xj 600s '99
Tue Aug 09, 2016 5:09 am
It's quite long time I've posted here, but I'm still XJ rider :)
I've not been doing many major upgrades in my bike but there are couple most important
- year ago I got rid of streetfighter look - so replaced lamp with classic round one with mini fairing:
- then I've replaced my heidenau tires with new brigdestones bt-45 (stock sizes) for better handling on wet
- installed Oxford Hot-Grips
- Last week I've noticed some serious fuel leaking - removed fuel tank and found this mess:
So I've cleaned it little bit, installed new air and fuel filters, fuel lines, and new fuel pump now it looks better:
jaszczomb
Tue Feb 28, 2017 2:37 pm
New season started, so it's high time to start thinking about new mods of my bike.
Firstly I wanted to change bar to be lower, clip-on's are too low, so I've decided to buy drag bar with same width like orginal bar (66 cm).
Unfortunately I couldn't fit it into original mounting because there was no space for cables below bars:
I was determined to have this drag bar so ordered 30 mm bar raisers
Much better, but still have problem with brake light switch:
Now I've removed this switch and lever is on acceptable position. But still I need to find either replacement for this switch, or just buy new smaller break pump (from R6 or something like that)
jaszczomb
Fri Mar 03, 2017 12:11 pm
New mirrors arrived
xjardin
Region:: ca
Motorcycles:: 1994 xj600sfc
Fri Mar 03, 2017 12:49 pm
Wow those are sharp! (pun intended)
Youtube Certified Backyard Technician
jaszczomb
Fri Mar 03, 2017 1:08 pm
They looks nice, but I had no time to test them today, so I'm not sure if visibility is acceptable. If not, I have 10 days to return them back.
Update: I like the look but they are too narrow to see anything but myself. I'll keep them, but they will wait till I buy some mirrors extenders.
jaszczomb
Fri Mar 17, 2017 12:47 pm
New toys arrived:
Big (55 teeth sprocket) was awesome in city, but now I need also to ride highways, so decited to go stock 48 teeth.
I did not have much time today for changing everything, but at least I've started to change sprockets and chain.
Here's photos 'before':
and after first stage:
Second stage I plan for Sunday ....
Fri Mar 17, 2017 2:49 pm
You are making some good progress. I'm interested to see the gold chain. I've been considering one for the Scrambler.
jaszczomb
Mon Mar 20, 2017 7:20 am
Today I've finished chain replacement.
started with some more cleaning:
Collected required tools:
And here we go:
Unfortunately I've broken washer that protects sprocket nut from unscrewing - one wing is lost so the only one is left - for now it looks that this one is pretty strong, but I've ordered new one so hopefully will get it by the end of the week.
