greeny's fab work!
greeny4704
Resident Expert
Resident Expert
As you all know im all about fabbing up just about anything! I have a unbelievable amount of equipment to work with and my work has no problem me using the equipment as long as i tell them im staying over to make stuff lol so here is what i have made so far that i have pictures of
1.5 id headlight mounts that have full udjustment (originally for my streetfighter headlight)
This is not the original y pipe that i fabbed for my xj but will be going on one in Georgia ;)
1.5 id fork clamps for steering damper
I use 1.5 inch istead of 38mm for 2 reasons 1: I have a supply of 1.5 mechanical tubing so it doesn't have a seam so the surface is smooth as and #2 is it allows for a coat of paint on the side of the tubbing to make up forthe difference in size and also keep the raw steel from rusting
BUILT NOT BOUGHT
This topic has 73 replies
